switching a 10 bolt to dana 44
Discussion in 'The Garage' started by 84PolarBear, Jun 22, 2002.
  1. 84PolarBear
    84PolarBear Registered Member
    Feb 19, 2002
    86
    San Francisco
    My Blazer is a 84, I am thinking about replacing my 10 bolt with a dana 44. Can I take an older 70's 44 dana and just bolt it in, or is there some difficulties.
  2. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    It should just bolt right up with no problem. ( as long as it is coming out of a full size chevy not a jeep or something. /forums/images/icons/grin.gif
  3. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    You are not going to gain a whole lot out of the swap. Axle diameter in a 10 bolt is 1.28" vs. 1.31" in the D44. The housing may be marginally stronger on the D44, but those are the only real differences. By the way, I'm running a D44 in my '86, but thats how I bought it.
    John
  4. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    i agree with skulznbonz unless its a 8 lug conversion or to match the gears in the rear axle changing it wont do any noticable good. /forums/images/icons/cool.gif
  5. 84PolarBear
    Feb 19, 2002
    86
    San Francisco
    I am wanting to match the gears in the rear axle, I am going to put in a 12 bolt with 4.10 gears. I hve to change the gears in the front to 4.10 aswell. Thinking it might be easier to put in an axle that already has the 4.10 gearing and manual locking hubs.
  6. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    if memory serve me correct i belive the 44 has a slightly larger r&p?!?!?!
  7. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    No, they both have 8.5" ring gears.
    The bolt right in place of each other.
    For the record, I went the other way from a Dana44 to s 10 bolt. Piece of cake.
    Swapping in the 14 bolt was easy too, but man that sucker's heavy.
    -- Mike
  8. 84PolarBear
    Feb 19, 2002
    86
    San Francisco
    Mike - did you change out the hubs to manual locking?
  9. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    The 10 bolt already had some clapped out manual hubs on it, which I removed and replaced with the Warn Premiums I had on the d44.
    The hubs were aftermarket, but just worn out. I've never messed with auto hubs.
    -- Mike
  10. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    im gettin 3/4 tons tomorrow and was wondering if the 14bff has locking hubs on it?
    NITRO
  11. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    You want to know if the REAR axle has lock outs on it? The only way to get lockouts on a rear axle is with a kit, like WARN.
    No, they come with one piece axleshaft that bolt to the hub with egiht bolts. And strong as hell.
    Bring a friend with you for the 14 bolt. It took three gusy to load in in the back of my truck, but in all fariness the other two guys were kind of smalll. Two big guys who haven't already hurt thier backs /forums/images/icons/smile.gif can do it.
    -- Mike
