switching efi 87 to carb fuel gauge issue
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gn4u2c, Oct 18, 2005.
  1. gn4u2c
    gn4u2c 1/2 ton status
    Oct 29, 2003
    287
    Pa 17329 zip
    this is an 87 pickup with dual tanks ,
    I'm helping putting a 400 sb in for friend and he wants to use a 750 edelbrock .fine I say. all in and runs fine.
    Problem fuel gauge is pegged all the time he used a mechanical pump and older non efi pickups in the tank.
    There are 2 wires that go to each pump (old efi units) so how the heck do we make the gauge in the dash work correctly ??
    Does he need a whole 86 harness or what ?? It still has a selector valve also
    Thanks !
  2. dyeager535
    26,979
    No difference in the sending unit gauge wiring, one wire no matter the year, additional wire for TBI is the pump 12V.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    If the gauge is pegged then the wire is grounded somewhere. Go check for any pinched wire to the sender along the frame rail or any bare wire touching the frame somewhere.
  4. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    What do you mean by pegged? If you mean the same as 3 o'clock then there is an open in the circuit. If you mean pegged on empty then it is short to ground.
    GM fuel sending units have been the same for YEARS! 0 ohms is empty and 90 ohms is full. In english that means grounded (0 ohms) is empty. An open (break) in the circuit causes the max ohms possible which is greater than 90, so the gauge winds up about 3 o'clock (as if it were a clock).
    A quick way to test if it is the sending unit is simply pull the wire that goes to the sending unit and ground the gauge side not the tank side. Make sure it is not the other wire that was for the pump. The gauge should read empty. If it does the the sending unit has seen better days OR the tank ground is missing. If nothing changes on the gauge then the open is somewhere between the gauge and the wire to the sending unit.
    If you want me to explain this a different way PM me and I'll do a better job. After all its 4:00 AM and I'm on my 10 straight day (night) at work. I'm not really sure I'm reading CK5 or just dreaming about it :crazy:
  5. gn4u2c
    Oct 29, 2003
    287
    Pa 17329 zip
    thanks will check it out. there is a pink and a gray wire going the sending unit we have the correct ends now to crimp on for the non efi sender . any one know what wire to use don't want to melt anything. :D
    cannot belive he tossed both efi pickups THEY were good!!!! those are expensive + I could have seen what wire went to pump and what wire went to the level sender AHHH :doah:
  6. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    IIRC, pink is the 12v feed to the EFI pump
