Switching from coil to HEI and Remote start solenoid ????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Jul 9, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    OK my motor we dropped in the 74 k5 has HEI, but hte k5 is set up (wired) for coil... so what the heck do i do???
    Colors????
    And the starter wires that go to the starter are way different than my 78 chev truck... so how do i hook the starter solenoid up??? /forums/images/icons/confused.gif
  2. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    I can help you with the HEI, all you have to do is run a wire from a point on your fuse block that is fused to the ignition switch(when the key is turned to the on position the line is hot) to the BATT terminal on the HEI. I swapped an HEI into my 73, thats all I had to do
  3. reddog64
    Nov 9, 2000
    3,325
    i'm lost... this is all i need to do to start the new truck up too...
  4. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    like he said for the distributor, just a switched 12 volt wire to the "batt" term. your old starter wiring has two wires to the starter, when disconnected from the starter only one gets power when the key is turned to the start pos., hook that one to the start terminal on the solenoid, the other one is no longer needed,you can tape it off or remove it.
