switching steering columns..
Discussion in 'The Garage' started by bryguy00b, May 25, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    how hard is it to switch a steering column. i want the one form my blazer cuase its got tilt.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    a few bolts, and a couple wiring harness connectors and a bit of time is all it takes /forums/images/graemlins/thumb.gif
  3. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    Make sure you get the actual ignition switch that bolts to the top of the column under the dash. Tilt vs. non tilt use different switches. They use the same connector but operate opposite of each other.
    Brett /forums/images/graemlins/burb.gif /forums/images/graemlins/k5.gif
  4. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok..thanx for the tip! /forums/images/graemlins/thumb.gif
  5. dyeager535
    26,976
    You will have problems if both vehicles don't have the same features though...column mounted dimmer switch, column mounted wipers, and key in column warning buzzer, as the wiring changed.
  6. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i think they are the same..the blazer is an 84 my truck is an 86
  7. dyeager535
    26,976
    '84 was at least a partial "changeover" year, so you might be right, everything might be the same, but make sure first.
