switching valve for duel tanks, how to test it Update one more ???
Discussion in 'The Garage' started by 84CUCV, Feb 28, 2007.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    switching valve might be bad. so how do i check it out? thanks :waytogo:
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    What year truck? FI trucks use a slightly different set up than carb'd.
    Check the switch in the dash first. It is a double pole double throw. Pull it out and make sure all of the 4 prongs do something. I had one dead pole on mine.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    its a 87 350, if its not the switch, how else do i check it? thanks
  4. burban1500
    burban1500 Registered Member
    Nov 27, 2003
    46
    Lavallette, NJ
    84cucv-will u part out that beater blazer?i want the rear
  5. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    i might part it out. i will be keeping that. sorry...
    If your looking i was told blewetts has a bunch of axles, even 1 tons. it sucks tho they pull it, not you. www.johnblewett.com
    later
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    found it the # there is 732.938.5331
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    anyone else??
  8. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    dunno if this will help....
    I did this in mspaint so enjoy my madd skillz.... :haha:
    this is how my 78 with dual tanks is wired....
    also side note... I think all the switch does is give power to the post on the unit...
    so if you take the part out... and ground it to the battery then hit positive it should click...
    someone please confirm first.. we dont need anyone blowing themselves up... :wink1:
  9. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    mine is wired the same as RootBreaker's
    is it not switching at all? try switching the tanks with the key on and the motor off and see if it makes any noise. mine is pretty noisy and you can hear it switching when the engine is not running.
  10. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK thanks guys got a good place to start now.
  11. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    do both tanks need to be hooked up for the system to work or can i just run it off one side? hope i can. that would be great need to be able to move it around. thanks
  12. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK i now know i can run it with one tank. i checked the wires for power. i was only getting 8v. it should be closer to 12v right? or am i wrong? thanks for the help
  13. RootBreaker
    Nov 29, 2001
    5,117
    173
    well shove the 12v to it to see if that does it...
  14. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK will see how it goes
