Swivel Frame/Joint
Discussion in 'The Garage' started by ks2krpt, Apr 1, 2004.
  1. ks2krpt
    ks2krpt Registered Member
    Mar 6, 2003
    47
    Adirondack Mts, NY
    Has anyone built a swivel joint so your frame can articulate over rough terrain ? What design did you use ?
    Will you share details ?
    Paul
  2. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    The only time I have seen this done was a dune crawler years and years and years ago. I believe they had driveline issues because they went so far as to drive all four wheels hydraulically. They had to use one big ass swivel point though. Not as big as a bus mind you but pretty big. Good luck to ya in the future.
    Allan
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    There was something like that on TTC 2003. This guy could control the movement by a thing in the cab. It was weird but cool.
  4. grd2go
    grd2go Registered Member
    Mar 28, 2004
    55
    Anchorage Ak
    Here in alaska they build them for moose buggys you can get the springs section out of the rear of a duce in a half army tk try a tk salvge yard for the parts with the pivot piece on it they cut the frame in half cap it and fab the two togather make a couple of stops to keep from going to far and all the ones I see usually have a divorced t-case mounted at that joint also. they run 56 in tires sometimes bigger. at the salvage yard the spring pieces can be found for around $50-$150 /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/crewcab.gif /forums/images/graemlins/k5.gif
