sx or ssr
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Jul 19, 2001.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    Right now i have a 6 in lift, and im looking at buying some new tires. I will be trimming my fenders some as well. What tire will work better at both rocks, and mud. I do quite a bit of both. Also, what would be a better size? 36/12.5, 36/14.5 or 37/12.5? One more thing, how any miles could i expect to get out of either tire?
  2. blazing86
    Dec 24, 2000
    290
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The bigest difference between the 2 are that the SX are Bias Ply tires and the SSR are radials. The SX have larger tred blocks and are tough as He!!. When I aired down my 36x12.5 TSL's to 8psi you could hardly even tell that they were aired down. Being a bias ply the SX have much stronger side walls than the SSR. I went with the 36x12.5 size because they are D load rated.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I was in the same delma until I relized I always drive my rig to the trail head so I am going with the SSR for the road manners. I will be steping up from a 33" mud tire to the 35x12.50-15 SSR. Probly gonna get the first two next week!
    I would say if you spend alot of time on hte hwy to get to the trail then go radial, if you trailer it go biasply....
    .02c
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    If you do any street driving (and most of us do a lot of that) the SSR is the way to go. Have had a set now for two months and I am very impressed with the LACK of noise they put out.........ride well, siping for wet traction, and they are plenty aggressive. Not sure how many miles you will get out of a set but they seem to be not too soft.
    By the way, they are also 10 ply.............seems they will be quite tough enough. I got the 35x12.5x16's...........with a 4" TC HD lift (plus the extra inch the Dana 60 gives) and RS9000 shocks.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.alloffroad.com>www.blazzinor.alloffroad.com</a>
  6. CCRider
    CCRider 1/2 ton status
    Jul 8, 2001
    314
    Charlotte North Carolina
    Got a set of 37x12.5x16.5 ssr's and they are awesome , had a set of bias ply regular swampers once , wore out fairly quickly, and were noisy! my buddy had a set of 33x15.5x15 sx's and they were by far the noisiest tires i've ever seen!!! but they lasted a good while! The ssr's I have seem to be wearing quite well , and work fairly good in the wet , considering the type of tire they are . SSR's ride well , sx's ride like s#*t!! but they have an almost in penetrable sidewall!!! Your choice , oh yeah if youve got a K5 you'll be trimming your fenders ALOT to fit 37's without contact when wheeling!! Unless you're a street driver.........CC
    1991 Fullsize 5 1/2"lift, 37"ssr's,10Bolt8 lug , 14Bolt ff, 4:56 Detroit rear, 12"fr. 14"r Bilstein remote res.350 P.F.I , 700r4 , 241c W/ sye
  7. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Hmm well from personal experience I do not like the ssr's. I wouldn't get them again. I have had them for a little over a year and they have less then 10,000 miles on them and they are getting worn down quick. I am a college student and i don't drive my blazer far at all. Hell sometimes i don't even drive it for two weeks. I have 35x14.50's if you want to know. I am getting two sets of tires next time. 35x12.50 at's and 39.5x18 boggers
    Doug Krebs
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Your rims are most likely too narrow if your tires wore out that fast. I think that especially because they're 14.5 wide. Get 15x12 wheels.
    I'd get the SSRs. In fact, unless I was going to get boggers, I'd never get bias ply tires.
    Tim
