SYE and/Or Dive shaft mods
Discussion in 'The Garage' started by mtex, Feb 7, 2006.
  1. mtex
    mtex Registered Member
    Feb 7, 2006
    15
    Houston, TX
    I am going to buy a 91' k-5. I plan to run 35" tires, should i run a 4" or 6" lift? Does either of these lifts require an SYE or Drive shaft mods?
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    4" If you lift the rear with a shackle flip, you should not need any driveline mods. You will need longer brake lines and shocks to start.
  3. djsblaze
    djsblaze 1/2 ton status
    Jul 7, 2003
    318
    Oklahoma
    I run a 6 inch lift w/ shackle flip in rear. I am running the JB converstion SYE kit. With 6 inches of lift, the drive shaft angle will be fairly steep for a Daily Driver. SYE kit will help with the angle, and reduce vibration...oh, I also have the NP 241 that should be in yours, mine is an 89.
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im planning on swapping in a 241+sye, id go sye if i was you, heard some bad stories bout slip yokes breaking at the wrong times
