SYE / Driveshaft questions
Discussion in 'The Garage' started by BigCountryx, Jul 25, 2005.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Is this Flange worth using on a 241
    They call it a SYE, but I know the one from JD Conversions is a real SYE, this seems a little sketchy to me, but I'm still toying with ideas.
    Anybody ever deal with driveshaftsuperstore.com ?
  2. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    Looks like the Neapco I have on the shelf - got it by mistake. It doesn't have a hole in the end, and it is nearly a foot long, I think it is a flange for a slip yoke.
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    That company has done business under quite a few website names - driveshaftsuperstore.com, arizonadrivelines.com, gloeco.com, and others. I have no direct experience with their products, but in my mind, any business that radically changes their website name repeatedly, while still in the same line of business, is covering something up.
    I'll let the members who have had good and bad dealings with them do the talking from here...
    Anyhoo, onto that flange... All it does is eliminate the slip yoke. It bolts to the end of the output shaft, allowing you to bolt a yoke to it. It does not eliminate the long output housing, therefore it doesn't give you any extra driveshaft length. I personally wouldn't use it.
  4. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    Yeah, I knnew what it did, just didn't know if anyone had tried it and if it was worth a flip :crazy: I guess the only advantage would be that the slip would now be in the shaft instead of in the tailhousing of the TC. That should get rid of some of the bind, ya think?
    And thanks for the heads up on driveshaftsuperstore. :doah:
