SYE for np208?
Discussion in 'The Garage' started by muddybuddy, Jul 1, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey guys, i know theres a SYE kit for the 241, but what about the 208? im about to do my 3/4 ton swap, and then get a HAD driveshaft, but i want to wait on that til i figure out what im goin to do bout my t-case, so i only have to measure once.
    any help is greatly appreciated
  2. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    The only one I've seen was a custom job. or it might have come out of a dodge? Can't remember............. :o
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    search...........
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    or would it be better to swap in a 241 or another t-case that is fixed?
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Swapping in a 241 and then buying a SYE for it would be easier but if you want to keep your speedo you can only use a 241 out of a 89'. Since in the later years they went to a electric speedo and all 208's are mechanical.
    To do a SYE on a 208 you need need the back half of a fixed yoke 208 out of a dodge. But there will be soem things that need to be welded in so you need to find someone that welds aluminum.
    Search next time this has been covered about 145454545445485733232 times :)
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    thanks, i appreciate it
    http://www.arizonadrivelines.com/SYE_Kits_$375.htm
    halfway down this page they say there is a SYE kit for 208/241. so i guess this will work with the np208? they make it sound like its the same kit.
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    DONT buy that kit, its just a toke that pretty much gets bolted to the end of the output shaft. Really junk if you ask me.
  8. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    That is NOT a true SYE like the one for the NP241/231 is. "10kandykmanic", but that is probably not spelled right, is the one I remember w/ the good info on this.
  9. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ya i didnt think so either. o well, i guess ill swap in a np241 and get the ord sye kit. that looks like the best thing to do.
    is there any advantage of my mechanical speedo vs. converting to electronic?
    ive got 8" lift on 88 k5 and planning on addin zero-rates, so the super shorty sye kit would help my shaft angle tremendously, saves 9" vs. the normal sye, which saves 5-6". every inch counts. the super shorty will only work with electric speedo, thats why i ask.
    i appreciate all the help from you guys.
    sorry if these are dumb questions
  10. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I have asked about converting to electric speedo but never got a definent (sp?) answer. There are some sensors and all kinds or crap that you need.
  11. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    what do you have to weld to swap to a dodge 208 output?? we didnt weld anythign on mine, just swapped the crap around
  12. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    what exactly did u do to convert yours to fixed yoke 208?
  13. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    im the 208 sye guy . i have a whole case fore sale if you are interested. ;)
  14. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im very interested, im going to need a cv driveshaft, and if this will save me alot of hassle from buying a 241 and gettin the sye kit.
    what ya got?
  15. big4x4ride
    Feb 11, 2004
    216
    Corpus Christi, TX
    got a dodge 208, took the input out swapped in the chevy 27 spline input and i was done
  16. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    One day I'll get your name right, sorry (again).
