SYE for the 208
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84CUCV, Nov 3, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Will the kit for the 241 from JB work on it or anyone else make one? thanks
    Mike
  2. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    no one makes one for ours
    you can rob the rear tailshaft/out put shaft off a dodge though and make it work /forums/images/graemlins/thinking.gif
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Actually no one makes a "GOOD" one for ours , the place Dave got his d44 from , and your gear guy works makesone but requires drilling and tapping th eoutput shaft , which may not be that strong at all
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    An NP241 should bolt right in place of a 208 so you can get a 241 and then do a SYE on it. Or you can do an SYE to a 208 using some Dodge 208 parts. It is not a direct install from what I understand though. So work is required to get the D208 parts to work in a C208.
    Harley
  5. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK thanks for the replys. I will start looking for D208.
    mike
  6. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    I got a 4x4 Garage mag and it says Driveshaft Superstore sells a bolt yoke kit that gets rid of it but doesnt make it any shorter.
    Later
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    i will look into that to. thanks
  8. zeroz400
    May 30, 2004
    410
    Libertyville, IL
  9. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    driveshaft superstore makes junk.
    get a 241. or... get an atlas
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have a good idea for a stock one , but lack capital to see it through , but it would of involved a new tailhousing kinda like a locking hub internally ( look at the internal part and how the inside turns with the axle and the body stays with the hub and rotor ) , on the end where it bolted over output and the flange inside tailhousing turned with the shaft while tailhousing stayed stationary , wouldn't shorten it at all , but it would be easy for someone with manufacturing facilities to make I'm sure . And make the flanged part same as front so CV's are easy as buying a front shaft and borrowing parts /forums/images/graemlins/thinking.gif
  11. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    I am going to look for a 241. thanks for the replys
  12. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    my plan is to find a 241 ans SYE it
  13. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    that is what i am doing now.
  14. zx672
    zx672 Registered Member
    Mar 2, 2004
    48
    Olney, MD
    Amen brother....those guys (Driveshaft Superstore)suck!!! /forums/images/graemlins/angryfire.gif
  15. big wheel bob
    big wheel bob Registered Member
    Nov 8, 2004
    14
    Hubert, N.C.
    I agree, bad business practices also!!
  16. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thanks guys will not be going there
  17. big wheel bob
    Nov 8, 2004
    14
    Hubert, N.C.
    If you just want to go with a cv joint, I do have slip yokes made for the 1350 joint, then you just have a soild shaft made, this is what we use in all my customer tahoe, and blazer vehicles. call if you like. 910 326 2881
