Sye?
Discussion in 'The Garage' started by bigbadchev84, Feb 11, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    how much would i expect to spend to get one of these kits? how much ange does it actually eliminate? and how hard are they to install?
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I believe the kits are somewhere around $350??? Plus you have to get a new rear driveshaft made.
    I think the "super short" kit allows for a 9" longer driveshaft. So assuming the stock shaft was around 32" you would have somewhere around 4 degrees less angle on the shaft depending on total lift height, that number increases as the lift height increases (shorter shaft increases angle quicker than the longer one as the lift height increases).
