SYE
Discussion in 'The Garage' started by TXsizeK5, Oct 16, 2003.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    How does this work for a 208 and how much am I lookin at to get a SYE, Shaft, and Driveline break from High Angle? /forums/images/graemlins/confused.gif
  2. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    IIRC no one makes a SYE for a 208. I could be wrong though. /forums/images/graemlins/grin.gif
  3. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    I don't know about compatabilty with the HI e-brake but I believe you can steal the parts for the SYE off of a Dodge 208.
  4. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    One driveline shop has a kit that basically is just a flange that slips onto the output shaft. You have to then drill and thread a hole in the output shaft for a bolt to hold the flange on. Then you can bolt up a driveshaft to that. I'll see if I can find the link.
    edit: Here is the link http://www.driveshaftsuperstore.com/slip_yoke.htm
    I want to go with a SYE for my 208 but I heard some bad things about that company so I am undecided right now.
  5. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    that kit is a welded cast iron part- Might want to check around a little more- Jess
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Do a search on this and K10ANDYHAMNIC(sp?)
    He has used dodge parts to do this conversion. There is one little part that needs to be welded to the inside of the case...other than that I think it is a bolt on.
  7. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    POST HYJACK IN PROGRESS.............
    What about a SYE in a 241? Is this possible using dodge parts? /forums/images/graemlins/thinking.gif
  8. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    The 241 has SYE kits that are "right" /forums/images/graemlins/thumb.gif
