Sylvania Silver Star headlight replacement guide
Discussion in 'The Garage' started by Eric M., Oct 12, 2004.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Sylvania
    Someone posted how well the Silver Star headlights worked and there was some confussion as to wether Sylvania made the Silver Stars for our year GM trucks. I was under the impression that there were only 2 types of headlight set ups from 73 to 87, 2 light and 4 light. Guess I was wrong. There is even a difference between the 4 light set ups for 87 pick ups and the 89 Burbs. I ordered a set for my 87 ... I hope they work better than the Halogens I have, I've gotta drive with my hi beams on when up in the mountains. Maybe it's just my eyes!
    Eric M.
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    yeh 89 is when they switched to the side by side lights instead of the over unders. Tell me how you like em, im thinking about a set for my truck, my lights suck
  3. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    try wiring a couple relays so your low beams have 100% voltage and current, this helps just about any rig.
    Watch those silver stars, the Cool blues I have been running in my PSD burn out quickly like in less than a year. Evidently the Blue or White lights are run on the hairy edge of their capacity to get the hotter light and thus do not last as long.
    Tim
  4. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Tim
    How do you mean? There aren't any resistors or form of resistance in the wiring path between headlights and alt. / battery source to reduce the voltage. And current draw is a relation between resistance of the load and voltage, you can't really limit that other than the originating source not having enough current for the load.
    I'll try anything, shot me a scematic (sp?) of what you mean.
    Eric M.
  5. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    The resistance is in the long wire run and headlight switch.
    Try this schematic .
  6. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    That makes sense. I'll let you guys know if these Silver Stars are brighter. If not, I'll give the wiring a try .... much cheaper than the next step, HID.
    Thanks for the link.
    Eric M.
  7. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I put these in my daily driver S-10. and I am disappinted in them greatly. They are a whiter light, but maybe as bright as my stock bulbs were.
    /forums/images/graemlins/dunno.gif
  8. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Well, that sucks. I guess I'll try the wiring solution if I have the same results.
    Eric M.
  9. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Now, on my motorcycle... I bought a PIAA bulb. Cost me $40!
    But it is supposed to be an offroad bulb and hold up to the vibrations better.
    Now that is a much better buld, no questions asked!
    /forums/images/graemlins/thumb.gif
  10. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,008
    609
    Pueblo, CO
    Eric M.
    If you got a multimeter, go out and measure the voltage at the bulbs with the lights on. Chances are you will see 12V or less at the bulb, even though the battery is at 14v when running. This is why the lights are not as bright as they could be. As it was said, the battery voltage goes from the battery, to the fues block, to the switch and back out again to the lights. All the voltage is being carried by small gauge wire. No, there is no resistor, but all that wireing is still resistance.
    I saw the schematic that DP_90K5 posted and plan on doing that exact setup on my 75. You'd be suprised what a actual 14V to the bulbs will do for brightness.
  11. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Does PIAA make headlights for our trucks??
    Eric M.
  12. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Also, you can get conversion kits for really cheap that convert from sealed beam to modern style plugin lights(9004,9005, and such). Even uses the same plug and they come in a variety of wattages, you can also get the blue ones and hyper whites. Check out JC Whitney.
  13. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Pretty saure PIAA does. I think my bulb is actually for a non motorcycle vehcile.
  14. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Got my Silver Stars and put them in. As Ken said, they are whiter but I doubt they are much brighter than the halogens I had in before. It's kinda hard to tell driving in the city, and it may be a little while until I hit the mountains, but from what I see, I'm not too impressed. I'll have to fool around with jumping a 10 guage wire directly to the headlights at night and see if the relay / rewiring deal works any better.
    Eric M.
  15. mcinfantry
    mcinfantry 1/2 ton status
    Dec 2, 2003
    308
    i put the silver stars in mine (7" round) and like them alot. not much brighter, but better pattern.
  16. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    What did you have in before? Halogens or regular headlights?
    Eric M.
  17. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    i did the conversion on my 85 burb. way better then stock. it vibrates alot though because the replacement housing is a tad smaller then the retainging ring. i have the silverstar h4 bulb in them and when those do out im getting some street glow bulbs. ive heard nothing but good things about the street glow bulbs.
