symptoms of a bad power stering pump?????
Discussion in 'The Garage' started by darkshadow, Jul 31, 2004.
  1. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    my pump was scueeling a bit befor and ever once and a whille, it would be hard to turn the wheel mid turn i checked and filled the resivor with fluid. and i got a bit better, but it still is a little hard once and a whille, it sorts jerks the wheel, like power comes bock then off.
    do you think its ready to be replaced?
    also my oil psi drops very low when idling after high speed, but comes back after i rev it, bad pump??? /forums/images/graemlins/dunno.gif
  2. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    whats your belt like?
  3. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    the belts a little loose but not that bad PITA to get it tighter. /forums/images/graemlins/ignore.gif
  4. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    Definatly time for a new PS pump, but the problem you describe with the oil pressure, is unfortunately you motor going south, sounds like the bearings init are getting worn to the point were they can't make pressure at an idle,plus the pump is a little worn also, sounds like it's time to start lookin for another engine, but I have been driving my ford taurus around in that same condition for over four years, just have to turn up the idle a bit and keep my foot onthe pedal at stop lights, and always make sure it has plenty of oil in it. good luck! /forums/images/graemlins/thinking.gif /forums/images/graemlins/waytogo.gif
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    common issues with GM RWD p/s systems
    belt slipping due to loose or worn belt, or worn pulley groove(mirror looking smooth in the groove on the sides and shiny belt sides)
    f belt is slipping then it usually causes jerking steering mainly at lower RPM
    if is noise growling all the time then pump is gone, if it makes noise when turning especialyl lower RPM then most likely pump is worn
    leaking, alot of them leak out the front shaft seal, time for at least a new seal if not new pump
    easy to find good used pumps, buy a dead truck of same year group as your p/s setup and swap if its in good shape not leaking and no pulley shaft slop
  6. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    the moter is a crate 350 from gm has only 60000 KMS on it and has been treated well. would it be worth it to get a new pump in it, or is it jus going to go on me anyway?
    the oil pump can be acessesed by removeing the oil pan right? /forums/images/graemlins/dunno.gif
  7. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    Even if you get a new PS pump if you can't get the belt tight it will still squeel and cut your Power steering on and off when the belt grabs and slips.
    Your oil pump problem, my first check would be the gauge since its the easiest check make sure it and the sending unit are working correctly.
  8. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    as far as the ps pump i think the tention needs to ba addresed, i was thinking of takeing it to a gerage to change all the belts just so i don't have to deal with it. its a PITA to do it, i could get it right if i had help, but i dont got any wrenching buddys, so.
    and i am sure the sending unit works fine, because it dose it so constantly and always responds to rpms.
    its not that hard to do a pump is it?>????? i might as well eh? /forums/images/graemlins/dunno.gif
  9. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    how hot is the steering pump and box when the pressure seems to fade? i would look into running a tranny cooler in the steering system.
    how low is low oil pressure. are you maintaining 10psi per 1000 rpm?
  10. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    well that question is a little hard to answer
    why?
    well i dont have a tac so i dont know my rms.
    and 2 mine in a canadian truck so the gauge in in kilopascals?????
    that is kg/Mx2 so 2.2 lbs per a square meter. i have no idea how to convert it
    the gauge has o-200-400
    start up idle-150-200
    cruse 275ish- 300
    idle at stop (after driveing) drops to almost 0
    but will kick up if i rev it
