Symptoms of a bad water pump?
Discussion in 'The Garage' started by stallion85, Sep 17, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    My bud has a firebird w/ a 305 that has been over heating. he came to my house and we were going to change the T stat but when he pulled up we noticed it was leaking coolant and gurgling (noise) around the water pump. I am pretty sure that's what is causing the problem. Just wanting a second opinion. /forums/images/graemlins/ears.gif Thanks for any help /forums/images/graemlins/pimp1.gif
  2. dyeager535
    26,975
    They leak water out of the bottom of the "snout" on the front of the pump.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have had them leak, but the most recent one had a pulley that wobbled like crazy (happened at real truck challenge).
  4. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    My most recent incident with a water pump happened in the middle of nowhere (south of Pueblo, CO. The bearing gave out -wobbly pulley, and when I opened the hood to see what was going on 200+ degree coolant was coming through the bearing seal, hitting the fan and spraying 20 feet out of the side of my hood /forums/images/graemlins/eek.gif ...I would say replace that pump in the comfort of a driveway rather then on the side of I-25 with minimal tools late at night. Just a suggesiton /forums/images/graemlins/waytogo.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Amazingly, my most recent bearing failure did not leak a drop.
  6. dyeager535
    26,975
    Friend has ruined multiple water pumps on his race car, probably similar to what you saw with the wobbly pulley. he runs (ran?) a flex fan and it appeared that for whatever reason, the water pump pulley was being pulled forward, taking the water pump shaft with it.
