Symptoms: Smoke at start up and high RPM and....
Discussion in 'The Garage' started by rafterman191, Oct 17, 2006.
  1. rafterman191
    rafterman191 Registered Member
    Aug 28, 2006
    54
    Indiana
    pulled a spark plug, covered in oil. SOmeone suggested valve seals and probably guides. Is it worth the work or swap the heads? Anyone have success with guide sleeves?
  2. AZ_Overdrive
    AZ_Overdrive 1/2 ton status
    Dec 18, 2002
    117
    Arizona
    My 89' Burb 350 does the smoke at startup thing. It's done that for the 6 years I have owned it. I looked into doing the stem seals and/or heads but everyone I talked to said live with it until it's shot and then rebuild the whole motor.
    I don't get any smoke at high rpm however and it still passes AZ emissions.
