symptons for cracked frame?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Kartoon, Jul 13, 2006.
  1. Kartoon
    Kartoon 1/2 ton status
    Jun 14, 2005
    171
    Massachusetts
    i have been having steering issues but i think that frame could be cracked. its a 1990 3/4 suburban, 4" lift with 35s. what happens is the truck will pull hard to one side, if i jerk the steering wheel to the opposite way, it will begin to pull to that side. but inbetween all this, sometimes it will drive in a straight line.
    I looked around the steering box but couldnt see anything, but i really should take the steering box off and inspect whats under it right? From searching i have found the ORD steering brace and repair kit which i am going to buy. Just wondering if this sounds like it will fix my problems for if its something else. thanks!
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    i would have someone turn the wheel while you inspect the steering box, watch it closely, and see if its walking off the frame, thats what i learned in my research a while back
  3. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Or see if the bolts are loose.
  4. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Symptoms of frame cracking? Cracks... Just look at the box mounting from under the vehicle.
  5. balterbuilt
    balterbuilt 1/2 ton status
    May 10, 2004
    385
    Santa Rosa
    check the balljoints too. have someone sit in the truck and see saw the steering wheel and see if there is ecessive wear in the balljoints. Also, grab the tie rod and see if you can move it (rotationally) by hand easily. These could cause you steering greif as well. Check your fluid level. If you don't see a crack on the backside fo the frame then it's not goign to be cracked on the other side behind the box either. Make sure the bolts are tight and check your steering column. The joint that meets the box could be toast too.
  6. Kartoon
    Jun 14, 2005
    171
    Massachusetts
    thanks guys, ill try the mentioned things and see if i can pinpoint it down.
  7. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I agree with the ball joints, a little play is all it takes. Had it happened to 2 trucks.
  8. mike n
    mike n 1/2 ton status
    Oct 9, 2003
    101
    New York
    Check for frozen axle joints.
  9. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    arent 3/4 ton frames alot tougher? seems like the frame wouldnt be the problem
  10. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
    i dunno but im dealing with a cracked frame behind the steering box in my one ton right now. had crossover with no hydro assist so that didnt helpp
  11. balterbuilt
    May 10, 2004
    385
    Santa Rosa
    3/4 ton 1 ton 50,000 ton, they can all break. Did you find anything out yet? Don't ya hate it when there is a ghost problem!
    RIght now i'm dealing with what i thought was the transfer case losing a bearing. We took the case apart, rebuilt it, noise was unafected! Ugh. Clattering so loud you can't think.
