Symtoms of a broken center pin??
Discussion in 'The Garage' started by MTBLAZER89, Jul 20, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I have a clunk in my front end braking and turning sometimes. It's just a small noise that I feel in the floorboards. Every component in the steering system is brand new. Just wondering if this is a possible broken center pin? I can't see any noticeble movement in the perch area ie. scruffed paint or anything like that. /forums/images/graemlins/dunno.gif
    I have zero rates with axle relocated 1" too BTW.
    Second question I'll throw this in since it is related.
    if I have to take this apart to check I am gonna redrill my perches for another 1/2" of wheelbase. Do I need to weld up the old holes first to do only a 1/2"?? Will the holes be to close if I don't? I think my driveshaft is just a bit too long, and I wouldn't mind a little more clearance at my firewall so this would solve two problems at once.
    Thanks /forums/images/graemlins/waytogo.gif
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    The clunk is probably in the leaf spring bushings either on the leafs or the shackel at the frame.
    Not sure on welding the holes up but I think you will have to. You need a 3/8" hole so they will run together.
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    have somone cycle the steering while you watch the spring. Also hold the spring while they cycle the steering. I could see the spring snap (for lack of better word) a little bit, when i did this. and it did turn out to be a broken center pin
  4. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I have watched the front end while somebody cycles the steering. Can't see anything moving /forums/images/graemlins/dunno.gif
  5. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    bushings don't look too bad, is there a torque value for the shackle bolts?
