Synthetic winch rope question
Discussion in 'The Garage' started by 88sub4x4, Dec 24, 2004.
  1. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    I bought AM Steel synthetic winch rope. Does it need to be wound onto the spool under a load like steel cable, or just giude it on tight and neat with hand tension?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Just guide it on the drum under heavy hand tension.
    Harley
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    It doesn't stretch so heavy hand tension is all that is needed. You will want at least a solid 8-10 wraps on the drum if you need to spool out the full length.
  4. 88sub4x4
    Sep 22, 2002
    792
    Long Island, NY
    Cool, thanks for all the info. I installed the new rope and fairlead, and now my winch weighs 42 lbs. less. I have it on a multimont that goes front or rear, and I take it out when not wheeling, so moving it is now a one man job! I didn't even consider the weight benefit when I bought this stuff.
  5. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    where in LI are you?
    Im over here right over the nassau border! Where are you there?
