T-case Adapter Woes
Discussion in 'The Garage' started by txfireman110, Mar 21, 2004.
  1. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    Well folks, I have now broken T-case adapter #3 and its starting to get old. /forums/images/graemlins/angryfire.gif (broke stock one, took it to machine shop and they "cooked" and welded back. Broke it again, bought one from a Ck5 member, broke it today.)
    So sorry for the ranting, what do I do? /forums/images/graemlins/dunno.gif Just keep fixing it, or modify/improve? What have yall done?
    Also, when I do my one ton swap soon, I'll go to TH400/NP205, does this same setup share the problems of my current TH350/NP205? /forums/images/graemlins/thinking.gif
    Thank You /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
  2. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    what kind of adapter do you need
    let me know I have a spare off a 86 that might work for you ....Jason
  3. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    This One (TH350/NP205)
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    where is it breaking?
    are you using the required gasket on the 205 side?
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Does your NP205 have the side mount that connects it the frame? If not, the adapter is trying to support the whole weight of a t-case that is mounted at an angle.
    Here is a pic of the side mount.
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    check your motor and tranny mounts. make sure they are A) serviceable and B) both polly or both rubber.
    also the side brace is a GREAT idea. it does help a lot.
    another thing is the torque bar that goes from the pass side t-case to the motor to bellhousing bolts. those help as well.
    Grant
  7. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Check the condition of your motor mounts and trans mount.
    Having one or the other in poor condition could be causing problems. Also maybe try leaving the trans mount bolts a little loose.
    Do you have the support arm that goes from the side of the t-case to the bellhousing? That could help.
    If you need one, I've got the one that was on my truck before I went manual.
  8. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    Thanks for the Replies!
    I do have the support rod that goes to the bellhousing, I DO NOT have that nifty looking one that hooks right to the frame, and my guess is that motor mounts are shot. The only tranny mount is the t-case adapter itself.
    (i'll get a pic of where its breaking ASAP.
  9. K1Orion
    Jan 8, 2003
    812
    st.louis,MO
    I think the "nifty" one is less common than the arm from the case to the bellhousing, I think LMC sells em if you can't find one.
  10. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    Please excuse the use of the word "nifty" /forums/images/graemlins/grin.gif!
    Here's where it is breaking.
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    replace worn mounts
    motor and tranny
    or dont tighten the trans mount to much
  12. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Brandon, did you break it before of after we saw you?
  13. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    Hi Derf,
    It was after, I went straight from there to Phantom, and broke it there. /forums/images/graemlins/doah.gif
  14. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    You sure everthing is bolted down good, something was banging pretty good when when Matt pulled you out.
  15. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    As far as I know /forums/images/graemlins/dunno.gifWhat did the banging sound like? The adapter definitely let go later though. (It makes a rather unnerving banging cause the tail lifts up so high the ears of the driveshaft wack the belly of the body!)
  16. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    How much slip do you have in your front driveshaft?
    I have broken one of those adapters while using rubber motor mounts and poly t-case mounts and truck pulling. Other than that, I have put them through alot of abuse with no side mount or strut bar (as the 350 was replaced with a 700r4 and didn't want to lengthen it) and have not broken it yet.
    I have seen a guy break several of them, but it was due to the front driveshaft bottoming out and forcing the case backwards (to look at the driveshaft when it was parked you couldn't tell there wasn't enough slip, but when he started to climb something and flex it bottomed right out).
    Just something to look at.
  17. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    /forums/images/graemlins/thinking.gifInteresting! I think you may have something there. The adapter does always fall backwards when it breaks and I have to shove it all forward to get it back in line!
  18. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    i agree with what Leadfoot is saying, on my 465/205 ive broken 2 so far i know now that it is the front drive shaft bottoming out [​IMG] you can see from the pic, so i had to make some bumpstop extentsions, since i can't afford a long travel spline shaft /forums/images/graemlins/crazy.gif
  19. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Brandon,
    What I was hearing might be unrelated, but might make sense. When you were gettin on it trying to get out and you body was moving up and down, etc., it sounded like you were missing a body mount or two.
  20. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    I'll check and see, could be since I have the body lift and all. Also, I wonder if what you heard wasn't my spare bouncing around in the back? It gets a little wild sometimes with out a mount and the strap I use always works loose after a while.
    Thanks for noticing, I'll check the body mounts!
