T-Case Adjustment
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Canuck, Jan 2, 2001.
  1. Canuck
    Canuck 1/2 ton status
    183
    Forrest, Manitoba, Canada
    The t-case shifter lever seems as though it is too far down ie: 1/2 inch below each indication. The t-case will not stay in 4-hi. How do I adjust this??? Is it as simple as the threaded rod attached to the t-case or is it something more difficult??
    Canuck
    BTW: Happy New Year to everyone on the K5 page
    Go Wide or Stay @ Home
  2. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I'm assuming you have the NP208 t-case. If so, the shifter adjustment is critical. It is detailed in the manual (HELM). If not adjusted properly, the range fork will go out (I'm on about my 5th one). If you use the truck hard and it has lots of body flex, I removed the gate from the floor shifter. This way there is less chance of putting stress on the range fork. There are internal shift detents in the t-case.
    Pete
    '83 K5, 350 TBI (ex 6.2), Dana 60/14 bolt, Detroits, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Do you have a body lift? i read on here that sometimes it messes up the linkage and it won't stay in the right gear.
    90K5
  4. Canuck
    183
    Yes it is a 208, and no there is no body lift on the Blazer. I had a quick look and could see there is a threaded rod with a linkage. I'll have a better look later on this week when I can get it on a lift.
    Thanks for the input so far.
    Canuck
