T-case breather?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazen91, Nov 5, 2000.
  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Where does your t-case breather run to?(i.e. under the hood beside the fire wall, atop the trans, etc.)Thanks
    blazen91
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    if you get about 2 or three feet of hose just coil it up and zip tie it together so that the coils are UPRIGHT.... do not let them lay flat or the bad things can get in.. make sure that the open end is pointing down also.. if you want you can run it up to the engine compartment somewhere but also do the same there to or install one of those plastic breather caps on the end.....
    ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]
  3. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Mine(np205) just runs to the body above the case. It does have one of those round plasit caps on the end of it. The rear diff vents to the inner frame rail, and the front diff vents to the side of the radiator up nice and high. I need to do some plumbing and run them all up higher than the carb. Which makes me think, does the SM465 tranny have a vent, or does it just vent at the shifter input?? That could be hard to seal and vent if so. Dang, tried to answer a question and now I have a question. Oh well, gotta love ColoradoK5.com
    Cruisin in my '73.
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I tried to find my breather for my 205, but it too well up in there. Oh well, I changed my fluid a while back and it looked good so no worries.
    -- Mike
  5. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Hey Goose, I've got the SM465/NP205 combo and recently had it out. Topside of the tranny is a breather, its just a stubby with a little cap. I think its threaded into the top of the tranny. I ran into a time crunch or I would have investigated a little more thoroughly into running sodt line up to the firewall. The T-case also has a breather on top and on mine it has a short rubber line and a cap. Most of this would be accessable if you remove the floor hump where it is bolted down. Hmm could be my next "to-do" project, like that list is getting any shorter[​IMG]!
    The shifter input is top-loader style, and I don't think there would be a way for the tranny to breath through it.
    If you ever need to remove the shifter or the top of the tranny let me know, there are a few little tricks that are hard to figure out just by looking at it.
    Rene
  6. Goose
    1,127
    Thanks for the info tRK5, I'll have to check it out and run all my vents somewhere high.
    Cruisin in my '73.
