t-case clocking
Discussion in 'The Garage' started by bronc3buster842001, Dec 4, 2006.
  1. bronc3buster842001
    bronc3buster842001 1/2 ton status
    Sep 30, 2006
    1,996
    6
    leadwood missouri
    when clocking the t-case wont that put the front driveshaft at a weird angle
  2. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    I once measured that if I clock 205 flat, front output rises about 4". So if you have for example 4" of suspension lift, d-shaft sees it as 8" of lift.
  3. iwaxmyjimmy
    iwaxmyjimmy College web wheeler Premium Member
    Nov 3, 2006
    2,802
    34
    Greenville NC
    break out the square tubing
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Want to explain that to me?
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Square tube front driveshaft - a smaller piece sleeved in a larger piece used as a driveshaft. Redneck special.
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah I kind of thought that was what he was on about but would like to know how that's going to sort out UJ bind!!
  7. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    a square tube shaft is not going to do anything to fix the angles. It is acheap way to make yourself a longer shaft with a lot of slip.
    this is my square tube with a broken 1310 joint. time for an upgrade.
  8. cbbr
    Jul 17, 2004
    14,681
    Won't cure that at all. Now that I read the question and response again, I have no idea what he was saying.
  9. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    there, fixed it for ya.
