T-case crosmember
Discussion in 'The Garage' started by dcell152, Dec 19, 2004.
  1. dcell152
    dcell152 Registered Member
    Sep 23, 2004
    84
    Nothern Maine
    Is there a differance in the trans/tranfer cross member on a gas and diesel K5? I had an 84 with a 6.2 that I changed for a 350. I know it came with dual exaust. I have an 88 now with a 350/std and there dosnt seem to be as much room around the T-case. I have Hedman big tube headers and they end about 2 inches befor the crossmember. I think I can order shorter collecters. worst comes to worst I can have one made.
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    1984 stuff and older had what we call a "Tall" crossmember and the 1985 to 1991 had the "short" crossmembers . Your 1988 would require you to run the passenger side under the crossmember while the older set up would allow both sides to go over the crossmember .
    There are pro's and con's to each style .
    HTH's , Tom
  3. dcell152
    Sep 23, 2004
    84
    Nothern Maine
    sounds easy
    So all I have to do is find a "tall" cross member that is befor 84. Its that simple? Thats sweet I have a t-case out of a 78 K5 and the cross member is still on it. Thanks for the info!!
