T-case & Doubler comparison thread...
Discussion in 'The Garage' started by TheBeast_88K5, Apr 16, 2012.
  1. TheBeast_88K5
    TheBeast_88K5 Banned
    Aug 30, 2010
    12,278
    [Far away.]
    I'm looking for a simple thread, or link, to the differences in doubler combos.
    Is there such a thread?
    :dunno:
  2. pblaze725
    pblaze725 build bash rebuild Premium Member GMOTM Winner
    May 28, 2007
    4,029
    123
    Dallas
    Pre-subscribed.
    I don't want to miss this one.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,138
    50
    Oak Harbor, WA
    There really isnt too much to compare.
    The 203/205 was the standard and only option for a long time as far as stock cases go. This gives you a 2:1 and 4:1 option. The addition of the Lomax 3:1 kit for the 205 gives you 2:1, 3:1, and 6:1 but is currently unavailable and $1000 plus which is in my opinion when combined with the doubler kit, inputs (if needed), outputs (if needed) and price of the cases if you have to buy them approaching the price of an Atlas, Black box, Stak etc.
    The other option is the 241/205. D&D was the only company for a long time that manufactured anything, but ORD has a kit forthcoming and I believe will allow you to use the much more common figure 8 205. The D&D kit requires the 86+ round pattern case which is more difficult to find and usually more $$. This setup will give you 2:1 (205), 2.7:1 (241) and 5.4:1 ranges. Same as an Atlas 4 speed. The 241/205 is a good setup IMO and I am currently piecing one together. It requires a little more fab work with having to cut the case up and tig weld the opening of the 241. The Driver drop 241's are plentiful and with ORD's kit including the figure 8 pattern 205 those are fairly simple to find as well.
    There are other variations like the 231/205 and the 231/Dana 300 which are comparable, but the 231 has a smaller planetary set than the 241. The above to are kinda the (fullsize) options. Otherwise you have the Black box, Klune V, Stak, Atlas for aftermarket underdrives/multi speed cases.
  4. NorCal_Chris
    NorCal_Chris 1/2 ton status GMOTM Winner
    Sep 25, 2009
    2,936
    9
    Sacramento CA
  5. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    58
    Fresno, Ca.
    I know I'm highlighting what Brian said but the 241/205 gives you the most flexibility and is a lot lighter than the traditional 203/205 doubler.
    If you don't want to mess with all the fab work involved with cutting the 241 case apart then a black box/205 will give you the same exact results and is bolt on.
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,161
    Sacramento, CA
    The black box, and before them the KluneV are a 241 planetary in a custom box, which actually makes it stronger, but more expensive.
    I too believe the 241/205 or any 241/2xx would be a good doubler and I bet cheaper than a 203/ 205.
    But I am going to assume that the OP was asking about the different suppliers of the 203/205 doublers, comparison between quality, price and ease of use, but I could be wrong.:dunno:
  7. Avery4jc
    Oct 24, 2005
    10,760
    58
    Fresno, Ca.
    I know, that's why I said it gives the same exact results (implying gearing selection).
    I think he's looking for a comparison of the different case combinations.
  8. TheBeast_88K5
    Aug 30, 2010
    12,278
    [Far away.]
    Nah... MTblazer89 hit it on the head.
    He explained everything I needed to know!
    Thanks, MT!!!
  9. BoondocK5
    BoondocK5 1 ton status Premium Member Author
    May 13, 2006
    10,000
    17
    Salt Lake City, Utah
    Having built my own 241/205 Doubler may make me a little biased.
    But, I thought it would be a good project. It turned out being rather stressful for me( I worry and brood over stupid ****, for way too long)
    Plus, when it came to the intermediate shaft, I had to basically plan, design, draw, and then describe to the Engineers at RCV Performance, what the shaft did and what it had to withstand.
    Then I was at their mercy for what seemed like forever, about 9 weeks for them to deliver it.
    But, it appears to function as advertised.
    RCV Performance also guarantees the shaft against breakage, lifetime guarantee. 'Nuff said.
    But in the end it was worth it, I got the doubler I wanted, learned alot along the way and made a good friend along the way too, David Burgess (sixb)
    If it were not for David and his machine work-expertise, it would probably have been alot more stressful than it was. My hat is off to David:bow:
    Check out the build at the bottom of my signature...(breaks arm, patting self on back:doah::D)
  10. Deuling
    Deuling "Official CK5 Post Whore" Premium Member GMOTM Winner
    Dec 8, 2010
    22,916
    1,139
    Muskegon Michigan
    Well since they have been compared. From people who have built them what are the costs for a complete build of each and costs of these after market units like the atlas etc...???
  11. BoondocK5
    May 13, 2006
    10,000
    17
    I figure mine cost me about $600.00 total Not including trade labor for some machine work.
    Plus I have the satisfaction of having built/designed it myself, with alot of help from sixb, David Burgess was in on most of the design and machining phase of it.
  12. BoondocK5
    May 13, 2006
    10,000
    17
    Is the ORD 241 kit out yet?
  13. MTBLAZER89
    Aug 14, 2001
    7,138
    50
    Oak Harbor, WA
    Not that I've seen. I have been watching cause I may just spring for the kit on mine and bypass the headache
  14. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    15,909
    1,705
    Afton / Star Valley Wyoming
    Just more info that I think is right
    ORD kit is the shortest
    D&D kit is the longest,
    NWF is the only one that lets you clock it to whatever you want basically and from what I have heard is just a touch longer than ORDs.
    FWIW I have a D&D 203/205 I like it just fine but if I was shorter I think I probably would have gone with ORDs, D&Ds is also cheaper than ORDs
  15. BoondocK5
    May 13, 2006
    10,000
    17
    I don't blame you one bit. After the headache of mine, I'm super hesitant to start anything near as complicated.
    It was a giant PITA!
    That said, I have another Intermediate shaft identical to the one in the doubler I built.
    I've had several requests to "build one" for other people. I have had to respectfully decline.
    It just takes too long for me to do anything that I'm being paid to do, and I don't want to disappoint.
    Plus, mine is unproven. I have not officially driven it yet.
  16. jt512
    jt512 1/2 ton status Premium Member GMOTM Winner
    Oct 19, 2006
    4,529
    4
    Maryland
    They have posted some pics of it in that pirate thread and IIRC someone from there even listed a price (I think :D).
  17. BoondocK5
    May 13, 2006
    10,000
    17
    Link?:D
  18. jt512
    Oct 19, 2006
    4,529
    4
    Maryland
  19. BoondocK5
    May 13, 2006
    10,000
    17
    Thanks man!:thumb:
    I have a username there. The whole (hole?) "As the PBB turns." just pisses me off.
    Homey don't do drama! Least not on da interweb!:D
  20. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    To my knowledge I was the first to post a build thread on a 241/205 doubler cause I searched hell and 1/2 of georgia for any info on this set up.As usual the more thats built the better they get and I've have saw others that have done things different than the way I did mine,most for the better.Since mines a trailer queen I mostly just use the 2.7:1 or the 5.4:1.Mine will actually slide the tires if I shift the 400 from drive to first w both cases in low.It also has pretty good compression braking.I built one cause it was more low for less dough and nobody (that I could find) had done one.
