T-case Drop, extend the linkage?
Discussion in 'The Garage' started by nofeartruckin00, Mar 28, 2002.
  1. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    My 4" lift should finally be here next week, and i was gonna drop the t-case right away with the stock spacers. Not sure if ill need to, but im figuring that it will vibrate if i dont drop it. So my question, when you drop the T-case, do you have to extend the linkage, or do anything else? '91 jimmy, 350, 4L60E, 241. Thanks in advance!
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I didn't have to. Every rig is different though.
  3. nofeartruckin00
    Oct 5, 2001
    798
    I guess ill just drop it and see if it shifts ok, cant hurt to try (i hope). Thanks!
  4. nofeartruckin00
    Oct 5, 2001
    798
    I'm just full of questions, geeze. What about the sway bar? When i put on the lift, will the sway bar still be able to bolt up, or will i NEED disconnects or some other extending item...lol
  5. BrownK5
    BrownK5 Registered Member
    Jan 8, 2006
    25
    gresham,OR
    i lifted my 79 k5 6" and i just left mine off. body roll isnt even that bad around corners either
  6. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    I have had to adjust the linkage each time I've moved my tcase.
  7. BudTX
    BudTX Registered Member
    Oct 4, 2005
    36
    Kansas
    You won't have to add swaybar extensions at 4", but you will at 6".
    I got the extensions on my 6" lift because it is also driven on the street.
