t-case drop temporary fix?
Discussion in 'The Garage' started by muddybuddy, May 22, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey guys, i posted last week bout 8" lift and driveshafts. but this thought just shot into my head. if i got like one of those 2" drop t-case kits, would that work temporarly with my stock rear driveshaft? i only need 2wd so i dont care if the front would work or not. this wouldnt be a long term fix, i would measure for teh driveshaft, then put the drop on and then when the shaft came take the drop off.what do you guys think? would it work? if so, what kind of problems would i be getting myself into? OR am i just an idiot for even considering this? :D haha
    thanks guys, i love ck5 i dunno what id do w/o it
  2. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    anybody?
    they sell a drop kit thats ment for 6-8" lift for $23 at rockymountains suspension. would i be able to run shock rear shaft with til until my new shaft comes? thanks
  3. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    oh come on! some one at least give an opinion. i hope my idea/ thought isnt that far-fetched.
  4. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I'm not sure how much the 2" drop would give you in driveshaft length. Have you got the shaft ordered? I'd just make (made) me a rear shaft until I could afford a good one.<----Still waiting after 2 years to "afford" a good one. :xmas:
  5. 1meanm1009
    1meanm1009 Registered Member
    Apr 3, 2005
    70
    bayarea,ca/mesa Az
    I have a 2"t case drop with a 6 " lift and i had to lenghten the shaft.Also i would have a cv shaft made way better for the pinion angle
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hmm so then even with the drop for 8" lift, it still might not work. o well i guess since its only $23 its worth a try. what kind of damage can dropping the t-case do, even if its for a short period of time?
  7. 1meanm1009
    Apr 3, 2005
    70
    bayarea,ca/mesa Az
    I blew the input bearing 2 times and it made a nice grinding sound on decel from high speed
  8. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    hmm i was thinking maybe, just maybe, you could use a 1" driveshaft spacer, drop the t-case 2", and use zero rate to move your rear axle forward towards the t case 1-1/2". when you get a new driveshaft ditch the tcase drop, ds spacer, and relocate the axle back, or move it 1-1/2 back from stock!!! maybe it will work
  9. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    i just got a longbox driveline and spent the 80.00 to have it shortened,balanced, and new u-joints and i was done with it
  10. blazerpro79
    Jan 4, 2005
    528
    Simi Valley, CA
    sounds good that way
    how much lift do you have??
  11. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    i have 8inch springs with zero rates and 6inch rear springs with 3 inch blocks, you might want to rotate ur spring perches for better spring angle too
