T-case Drop
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ChadH82, Aug 1, 2001.
  1. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    Stillwater, Oklahoma
    On my blazer I'm going to have about 8" of lift. I think I'm going to drop the case a little. Is it ok to drop it an inch and a half(1 1/2")? If I do that I'm going to use bushing spacers with grade 8 bolts. Will this make the front yoke on the case point up to much? Let me know.
  2. It will put alot more jam as rene would say on the front shaft joints. Also it may cause the front shaft to hit and rub your exhaust. At least it does on my 90.
    Also, you have to make sure that your fan shroud is clear of the fan and it does put more stress on your motor mounts.
    Damn I need to learn how to use my welder!![​IMG]
    (90 Jimmy 350 TBI, 14 FF/10 bolt, 4.56, tires ??
