T-Case fluid change
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Aug 27, 2000.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I think I will be doing this soon. I have a few questions. First does anyone know what size the drain and fill plugs are? Its an NP 241. And I dont have sockets that big. Also what is the best way to fill it? Can you use a squirt fitting thing from a gear oil container or would a funnel work better? It uses Dexron III ATF right? How many qts. do I need? Thanks in advance
    90K5
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    You can pick-up a fluid pump from any auotstore. I got one that is used to pump fluid from fleet sized containers. Spent $4. If you dont want to go that route then just empty one of those squeeze H20 bottles. Let it dry out completly. I have an NP208 so I really cant help on the fluid type or capicity. I didnt have the size wrenchs either. I used an adjustable wrench to get mine off. Not too bad. Didnt round off either one. Well thats my $0.02 back to the Simpsons.
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I bought a case the last time I changed my fluid, It took about 11 gts.
    creepin' and crawlin'
    Jim
