t-case help
Discussion in 'The Garage' started by bigboyblazers, Aug 23, 2005.
  1. bigboyblazers
    bigboyblazers Registered Member
    Jul 31, 2005
    12
    ellinwood,ks
    I have a 203 t-case. With the shifter in 4-hi or 4-lo and my hubs locked in I still only have 2wd. If I shift it to 4-hi lock or 4-lo lock I get a popping noise. Any help would be great. Thank you.
  2. mudman83
    mudman83 1/2 ton status Premium Member
    Feb 11, 2004
    141
    Mesa, AZ
    Put it in 4 wheel drive and then put the transmission in park. Then go underneath and try to spin the front drive shaft with the front hubs unlocked. If it does spin your transfer case is not going into four wheel drive and somehthing internal is broken, most likely a chain or shifter fork. If it does not spin, then you know that the drive shaft is at least connected to something, and it is either in the front diff or hubs, which are easy to pull off and check.
  3. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I think your chain may be stretched, and is jumping a tooth. I have the same problem. Go to the tech section on this site, and read the write-up on the Mile Marker part time kit by Grim Reaper. He addresses this somewhat. Mine only makes the popping when it's under load, albeit a very light load, if I'm just cruising in 4, it doesn't happen. Like I said, I think it's a stretched chain, for which 203's are notorious.
  4. JonV
    JonV Registered Member
    Mar 17, 2003
    27
    Hesperia, CA
    p.s. chains don't stretch, they wear.
  5. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    every owned a dirt bike? chains streatch like a Mo Fo. service life is determined by stretch. T-case would be similar IMO
  6. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    i work on mountain bikes- chains stretch-alot :D
