t case identification question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by offroad87, Mar 2, 2004.
  1. offroad87
    offroad87 Registered Member
    Feb 2, 2004
    57
    Atoka, TN
    i have a 87 K5 with a broke np 208. i got another one today, but im not sure what the differences are. on the broke one the tag reads:
    208 C 2
    1400 8249
    1 8 87
    261
    the one i got to hopefully replace it reads:
    208 C 1
    1400 8249
    1 2 86
    261
    the only differences in the numbers are the model one is a 208C2 while the other is a 208C1 and of course the build date . what does the last digit of model # mean. by the way, im new to four wheel drive trucks so please bear with me.
  2. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    if i remember right i think that hads to do with the case/model number of the t-case i had the same problem once but found out they were all the same inside and all the parts were inerchangable.
  3. offroad87
    Feb 2, 2004
    57
    Atoka, TN
    i havent pulled my case apart yet but the main thing wrong with it is that the case is cracked all the way around it. im not sure if their is anything wrong with the internal parts. im going to hopefully find time to pull mine tommarro and compare the two. im also running a 700R4 if that helps any. /forums/images/graemlins/dunno.gif
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    the only thing you want to check is the spline count on the input, your 700ra wants 27 spline, the th400 wants 32.
    I don;t know if the C2 would be for 32spline or it's just the later years.
    The spline count is the only difference between all GM 208's
  5. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    even if it is a diffeeent spline count...chances are he can swap the inputs...its probably not the input that went ka-boom
  6. dhdescender
    Aug 10, 2002
    628
  7. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    if u run into trouble when u get the old one out. don't hessitate to gimme a call.
