T-case Keeps popping out of 4hi
Discussion in 'The Garage' started by kyser_soze, Oct 31, 2004.
  1. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I have a NP 208 that keeps coming out of 4 HI is there an adjustment to the linkage. By the way I went 175 feet in the mud pit in 2wd with my baja claws /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
  2. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    That musta been a really shallow pit or you have a serious engine that spins your tires like mad!
  3. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    I had a similar problem and the shifter linkage just need some adjustment. Just look under the truck on the passenger side and you will see it.
    Check out the midwest forums for local guys and runs and capitalcitycrawlers.com for another local club.
    Blake
  4. ColAdo82K5
    Feb 18, 2000
    789
    MO
    Profile says.....468 cubic inchs...sounds good enough for me.
  5. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
    Will do not too much mud kicked under there this time! /forums/images/graemlins/whistling.gif
    Blake
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Mine did this also and I just adjusted the linkage also, it will fell firmer and more positive when it is adjusted right /forums/images/graemlins/thumb.gif
