t-case leak
Discussion in '1992-Present Chevy & GMC models' started by Frankenstien, Nov 23, 2002.
  1. Frankenstien
    Frankenstien 1/2 ton status
    Aug 3, 2002
    167
    Lewisville,TX
    90 model heavy half leaking out the back where driveshaft goes into t-case (241 is the case) looks fairly straight forward to replace that seal anything I need to be fore warned about?
  2. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    nothing tricky, just pull the shaft and tap out the seal. some fluid may trickle out, but just be ready and wipe it up. then tap your new seal in. you're good to go /forums/images/graemlins/cool.gif
  3. Frankenstien
    Aug 3, 2002
    167
    Lewisville,TX
    thanks man, it doesn't get any easier than that
    did make a little mess in the wife's parking spot in the garage /forums/images/graemlins/smirk.gif
