T-case leaking after driveshaft swap?
Discussion in 'The Garage' started by hidesertwheelin, Nov 19, 2005.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    First of I have 90 Suburban w/ a 700R4. I just installed my HAD rear driveshaft w/ a slip yoke (ya I know, but I got it from a CK5 member cheap). Now it leaks. The t-case fluid is running down the slip yoke and then dripping? How do I stop this?
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    replace the seal,,i found this usually happens when you remove the driveshaft, not sure why, but the seals are only a couple of bucks.
