T-case leaking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by walt88, Jan 28, 2001.
  1. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    My transfer case is leaking from the very bottom. Very minorly. where is the most common place for a t-case to leak.
    Keep the shiny side up, and the greasy side down.
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Good question 'cause mines doing it too. I should tear it apart and stop all those annoying leaks. Does anyone know of any seal/gasket for the 208C?
    June 2001 - The Texas Sawz All masacre begins. Be afraid rust, be very afraid. [​IMG]
  3. walt88
    May 24, 2000
    430
    Monmouth County, NJ
    The thing is is that there is barley a leak. It is coming from the dead bottom where the lowest bolt is. I just wonder when things are going to god damn stop leaking on my truck!!!!
  4. dewey
    dewey Registered Member
    Dec 17, 2000
    59
    MA
    Did the seal dry out? Don't they sell some "magic in a can" that swells seals, so the leak stops?
  5. walt88
    May 24, 2000
    430
    Monmouth County, NJ
    I am gonna take a better look tommorrow
    so we will find out.
  6. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    I had the same problem w/ my 241. A buddy of mine who rebuilds trannies said that the problem was a bad design at the factory. Apparently the seal faces are smooth and don't hold a seal well. His remedy was to throw out the gasket, scibe the faces in the middle of the machined surface (for a place for the silicone to grab) and orange goo'd it. It fixed all of the leaks except one. But that's a crack in the case. Eventually I'll get that welded (when it's warmer out). This is for an aluminum case. Will it work on your cases?? Don't know, but it's worth a shot.
    Why do people keep calling it a Bronco!!!!!
