t case linkage after droppping
Discussion in 'The Garage' started by the excuse, Mar 1, 2004.
  1. the excuse
    the excuse 1/2 ton status
    Dec 9, 2003
    209
    san diego
    after i dropped my transfer case the linkage seems very rough. how do i fix it.
  2. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    crawl back underneath your truck and adjust it. Off the shifter arm under the truck the t case has a long threaded rod with 2 jamb nuts and the linkage attachment. Loosen the nuts up and adjust till it feels normal again. Shouldn't take you more than 5 minutes...
    I'm going off your profile stating that you have a 208. This is the method on my 241 SOOooooOOOooOOO...
  3. the excuse
    Dec 9, 2003
    209
    san diego
    ok thanks ill try that. so i just loosen the bolts put it in 2 high and tighten them back down?
  4. Kyle89K5
    2,273
    OKLAHOMA
    Pretty much. You'll prb. need to test it out a couple of times to make sure it's where it fits good. More than likely, it's just a little bound up. Not real uncommon, mine has gone through 3 different mods that all required adjustment. Just loosen it up, get it out of the bind so it's ready to move freely, then tighten it back down. /forums/images/graemlins/thumb.gif
