T-case lowering----Curious
Discussion in 'The Garage' started by jackedjimmy, Jul 19, 2002.
  1. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    I did a search and found good info on how to do it and i know why you would have to.
    But by lowering the t-case by flipping the spacers, isn't that really just tipping the whole drivetrain back and putting stress on the engine mounts? This would also make the angle for your front driveline more raddical right....
    Unless I'm missing something
    Anyway, I'm nowhere close to this point, but just curious.
  2. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    i dont know about motor mounts being more stessed but it does put more angle on the front shaft...you can buy a 1" spacer made by superlift that can help push out the shaft so it wont be such a big angle...
    Later
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    so if i lower the t-case with the 1" spacers and put the spacer from superlift in my front D44, i'll be ok?
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I've got my t-case lowered 1" without a spacer on the front driveshaft...No problems at all. Been this way for 8 or 9 months now. /forums/images/icons/grin.gif
  5. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    i ran a 6" kit for about 2 years with the t-case lowered the 1" and never had a problem with it...now im running almost 10" up front and my driveshaft wont go in...so im gonna run the spacer up front and rerun my exhaust so the factory crossover pipe is no longer in the way...
    with 6" or less you should be fine just dropping the case 1" and thats it...if you have problems with it get the spacer...its only 50 bucks
    Later
  6. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    yes and yes
    it does make the front driveshaft angle worse, and yes it does stress the motor mounts more than before...
    however, i did this on mine when i put my 4 inch lift on, and it made a big difference...
    my rear driveshaft was binding up when i let off the gas at like 50 mph...
    lowered it and instantly stopped..
    my front driveshaft was made stock to be in a higher angle situation since it has the extra joint by the transfer case, so a little more angle didnt cause any additional problems...
    and as far as the motor mounts, sure they're stressed a little more, but nothing to worry about...
    made the engine swap a hair more difficult, but had i not done it before i wouldnt have known any difference...
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I was under my sub today and noticed that there isn't any spacers from the factory to flip to the other side, and i also noticed that my crossmember is connected to the top and bottom of the frame rails. So will i have to make my own spacers? '75 K10 burb NP203 350/TH350 w/ 33's
  8. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    most likely yeah you will have to make some...theyre not hard to do...we made some for my buddies k30 a few weeks ago...took some small diameter steel tubing and just cut it down to about an 1" a piece and bolted it in...didnt take long at all
    Later
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    True, won't be hard to make at all, since I have use of my dad's lathe and/or mill /forums/images/icons/smile.gif
  10. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    there you go
    Later
  11. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    I Ran a little mor ghetto setup. just took an inch of washers and stacked them up seem to hold fine. I think im gunna do it right though in a little bit.
  12. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Only thing that is gonna suck for me is that I have to make 8 of the spacers.
  13. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Make your spacers out of one solid piece of metal in stead of two little unstable spacers per side. Use a piece of 1" sguare tube or something along those lines. You will retain the stability of your crossmember this way.
  14. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yeah i know that, its just that my cross-member is bolted to the top and bottom frame rails.
  15. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Mine was bolted to the top and bottom rails too....Now it's just bolted to the bottom rail. The part that bolted to the top rail on the passenger side, I just unbolted and left it there. The one on the drivers side that wraps around the outside of the frame and bolts to the to the top of the frame rail, I unbolted, then cut the rest of it off with the plasma cutter. Now it ends at the frame rail. Nothin wraps up around the frame any longer. I've got a piece of 1" square tubing for a spacer. I've been runnin it this way for almost a year, and have had no major problems. The only problem I've had since droppin the t-case is sometimes it pops outta 4 low....Thats just cause I havent gotten around to adjusting the linkage. /forums/images/icons/grin.gif
