t case lowering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shaggyk5, Mar 2, 2000.
  1. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    i was told that for a four inch lift you should lower the transfer case to provide a better angle for the driveshafts. My questions: how? how far? is this neccessary? how can the t case be lowered independantly of the trans? i have a funny feeling its not as complicated as i am making it in my mind, but i want to double check! thanx in advance!
    shaggyk5
    aint nuthin in the world like a heavy chevy!
  2. Texan
    Texan 1/2 ton status
    153
    Leander, TX
    Your trans. basically hangs between the t-case and engine so when you "lower" the t-case you are really pivoting the entire engine/trans/t-case package at the motor mounts....
    Hope That Helps,
    <font color=orange>STEVE<font color=orange>[​IMG]
    89 Blazer
    67 Camaro 468
    68 CamaroSS 327
    98 GTP
  3. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    With my 4" lift, my tcase isnt lowered at all. I have no driveline vibrations at all. I dont have shims on the axle's either. Guess I just got lucky.
    Also, if you do lower your tcase and dont have a body lift, you run the chance of your dist hitting the firewall. So be careful.
  4. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    If you can get the angles between your driveshaft/axle pinion to be equal to the angle between the driveshaft/t-case yoke and these angles do NOT exceed the allowable angles of the u-joints you are running, you should not need to lower your t-case and should not experience any driveline vibration. If this doesn't work, another option is to have a CV-jointed driveshaft built and have the rear pinion rotated up to be inline with the shaft so that you wouldn't need to shim or lower the t-case.
    Good Luck
    Brian
    Still in search of the TBI KING
  5. shaggyk5
    1,610
    SE pennsylvania
    how would i go about lowering it if i did need to?
    shaggyk5
    aint nuthin in the world like a heavy chevy!!
  6. OneInTheSun
    OneInTheSun 1/2 ton status
    160
    Pittsburgh, PA
    For some reason, Chevy used spacers when they bolted the t-case to the frame. Just move those spacers (I think they're 1/2 - 3/4") between the t-case crossmember and frame. I had some serious vibration after I put on a 4" Superlift lift. Lowering the t-case helped tremendously. The u-joint angles are still a few degrees off, so I'll be replacing the shim that came with the rear springs with shims that even everything out. Seems like some people have this problem and others don't - guess it depends on the brand of the lift.
    <font color=blue>Rob
    85 K5</font color=blue>
    [​IMG] 24 beers in a case, 24 hours in a day - Coincidence?
  7. kim tate
    kim tate 1/2 ton status
    134
    New Orleans
    Spacers?
    Please help clear this up for me. Do the spacers (stock K5) go between the crossmember and the frame?
  8. Crash90K5
    Crash90K5 Registered Member
    84
    Santa Clara, CA.
    Re: Spacers?
    Nope, for the stock setup it goes frame -> cross member -> spacers -> nuts. To "lower" the t-case, flip the spacers to go between frame and cross member.
    [​IMG] <font color=blue>Crash90K5</font color=blue> [​IMG]
  9. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Re: Spacers?
    Crash is right. I had the same problems with driveline vibrations when I put a 4-inch lift on my rig. Did the exact same thing with the spacers and it helped out a bunch. It sure does beat going out and buying a set of spacers.
    BIGJ
  10. Mr Red
    Mr Red 1/2 ton status
    263
    Washington, DC Metro Area
    Get this. The guy I bought my rig from had it lifted (4"). They used a bunch of washers, just under 3/4" b/t frame and t-case mount. Looks like sh*% rig but I got zero vibration. As I get older, I'm lear'n not to question things like this that work!
    <font color=red>David, '86 K5</font color=red>
  11. drifter
    drifter Registered Member
    Feb 20, 2000
    39
    Western Oklahoma
    I put a 4" pro-comp on my 79 and had bad vibrations. I called the place where i bought the kit and they told me to move the spacers like Crash & Bigj did, it worked no more vibrations! [​IMG] Life is grand in k-5 land [​IMG]
  12. shaggyk5
    1,610
    SE pennsylvania
    thanks everyone!!
    shaggyk5
  13. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    How much lowering?
    How much did you guys lower the transfer case to make the vibrations dissappear?
    Just gettting smarter for the day I decide on a lift kit.
    <font color=purple>////////
    Go 79s!!!
    </font color=purple>[​IMG]
  14. drifter
    Feb 20, 2000
    39
    Western Oklahoma
    Re: How much lowering?
    Blazer 79, about 3/4" to 1" worked on mine
