T-case lowering?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BozoWise, Jun 27, 2002.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I just flipped the rear shackels and removed the blocks to get a 6" lift in the rear. Going to get a set of 6" TC springs for the front. Should I lower the t-case on my fulltime case? If so where can I get a kit? Can I build one? Thanks for the info.
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    On my 4 inch, I just used the 1 inch "spacers" that GM supplied for the transfer case x member mounting bolts. I don't know if a six inches will need more than 1 inch drop.
    John
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    All you need to do to lower it 1 inch is use the spacers that are already there /forums/images/icons/grin.gif they will be on top above the frame just move them between the frame the cross member and your set /forums/images/icons/smile.gif
  4. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Thanks should an inch do the trick? I'll have to check and see if my 79 has the spacers there.. Will check in the AM
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    it should do it but each truck is different lol all blazers have the spacers from the factory unless someone took them out /forums/images/icons/shocked.gif
  6. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    If you don't have the spacers ... I think you can just use 1" square tubing. Like Mudhog said all rigs are different....
  7. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Thanks guys ;-)
  8. Blazin Ed
    Blazin Ed Registered Member
    Mar 29, 2002
    92
    Seattle
    After I lowered my transfer case 1" it got rid of the low speed vibration but now when I accelerate in reverse it makes a loud grinding sound on the firewall! Any else experience something like this?
  9. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Mine hasn't yet, but I also have a body lift on mine.
    All hte spacers were there all I needed was the impact w/ 11/16 and a 5/8 backup took me about 20 minutes w/ 2 smoke breaks ;-)
  10. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Make sure the driveline is not rubbing against the muffler heat shield. The torque in reverse might be kicking the tcase over just far enough for light contact, when the t-case is stock height it is above the heat shield.
  11. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Another thing to note.... As most of us have lowered our T-cases this way... (including myself) these lengths of tubing and their little contact patch between the frame and the crossmember really take some of the strength out of the crossmember. It no longer contacts the frame in a smooth wide flat area to keep things rigid, I think this allows some exta frame flex. I will be removing mine and using some nice flat, square thick wall tubing to get it back into direct contact with the frame.
  12. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Great point Tori
  13. trailblazer87
    Jun 11, 2002
    707
    Madera, CA
    Skyjacker sells a lowering kit for about $25, it comes with new grade 8 bolts, nuts, washers, and 4 grade8 plates that fit in between the frame and crossmember, its what I did to mine.
  14. Blazin Ed
    Mar 29, 2002
    92
    Seattle
    Thanks for the advice Trailblazer, I'll check the muffler heat shield when I get home from work!!!
