T-Case Lubricant
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wfo163, Apr 17, 2003.
  1. wfo163
    wfo163 1/2 ton status
    Jan 11, 2003
    100
    Charlotte, NC
    This may seem like an arbitrary question but I am in the process of repacking my np 205 with all new seals and gaskets and was curious if refilling this thing with gear oil instead of ATF is permissable. I cant imagine why it would be bad for the all gear drive rather I think it would be beneficial as it seems to me that ATF is just to thin of a fluid for a transfer case. Any input is appreciated. Keep on wheelin'!
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I think 205's are supposed to be filled with gear oil. If i remember right the 203's and 205's take gear oil. 208's and 241's take ATF.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    That's what I was thinking too. /forums/images/graemlins/thumb.gif
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I THOUGHT MY OLD 203 WANTED ENGINE OIL, BETTER CHECK....
  5. 74Chev
    74Chev 1/2 ton status
    Sep 19, 2002
    102
    Oregon
    This is what the factory calls for and were factory filled with.
    NP 203: 10w-30wt. motor oil
    NP 205: 80w-90 gear (Canadian vehicles and colder climates call for 80w or 75w-90)
    NP 208 and NP 241: ATF Type Dexron
    I do know that Dodge in the 1980's called for ATF in the 205's that were available in their heavy duty trucks, probably to help increase gas mileage due to federal regulations concerning Corporate Average Fuel Economy.
  6. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Don't put gear oil in your 203...they don't like it. I have seen people run ATF in 205's w/ OK results...but I would stick to the gear oil in the 205's.
  7. Grim-Reaper
    7,385
    Atlanta
    WHere it's real cold people will run ATF in the case in the winter.
  8. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    My shop that rebuilt my 203 put gear oil into it... I asked them about the oil slinger and when it was apart they showed me it had no slinger and said that the upper was lubed by the chain slinging it...I believe thats why I have to lock the hubs every 200 miles as recommended by Mile Marker...
  9. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Please tell us the shop name and location.
  10. rcpilot
    Feb 22, 2002
    507
    Central Cali
    Summit Transmission in El Cajon, CA
  11. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    motor oil in a 203 from what i've heard, gear oil in a 205, ant ATF in a 208
