T-case making noise while coasting
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by balzackks84, Mar 18, 2003.
  1. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    It happens when I'm at speed. It starts at about 35 MPH and gets louder from there. And it only happens when im coasting. If I slam it down a gear going down hill it will go away cause its under a load. And I've got a brand new slip yoke on it with about 1/4 to 1/3 of it sticking out of the t-case. Its a 208 and I just took a grinder to the ears on the driveshaft and yoke to make sure it wasn't those ticking together. What the heck is causing this?
  2. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Hard to tell without explaining what kind of sound it is..
  3. balzackks84
    Aug 22, 2002
    1,344
    portland, oregon
    Hmmmmm... The best way i can describe it is it sounds like the ears on the yoke are slightly hitting. Its not a grinding noise but some vibration is felt in the floor boards. And I know there is enough fluid in it cause I got a big money shot when I pulled the slip yoke out to check if the ears were actually hitting.
  4. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    Sounds like a pocket bearing starting to go out. real easy to replace. I just replaced one in a customers 208 last week at work. It only made the noise while coasting around 30 to 45 MPH.
    Colin
  5. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Do you have a CV shaft on the rear driveline?
  6. balzackks84
    Aug 22, 2002
    1,344
    portland, oregon
    Just a slip yoke and single u-joint.
  7. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    sounds like gear rattle -the angles are too extreme you need a c/v and a 2 degree working angle at the diff and it will go away- jesse /forums/images/graemlins/thumb.gif
  8. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    ...I got a big money shot when I pulled the slip yoke out...
    [/ QUOTE ] ROTFLMFAO!!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  9. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    I got a big money shot when I pulled the slip yoke .
    i will second that ROFLMAO /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  10. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Does it sound like a pipe dragging on the road? Like a rattleing vibe noise. I get the same thing, a bad driveshaft angle causes it. Try dropping your tcase or adding angle shims to your axle. If those don't work a CV shaft would solve that for sure.
  11. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Kind of a whining noise that only appears at speed and when not under load? It almost sounds like a brake lathe that isn't doing any cutting. Beats me, but I've got it too.
    It sounds to me like one of the many bearings in there are getting ready to let loose.
  12. balzackks84
    Aug 22, 2002
    1,344
    portland, oregon
    Well if everyone has this problem but no ones breaking I guess that means I'm good to go /forums/images/graemlins/thumb.gif Only a 200 mile round trip to the beach, and maybe some sloppy wheeling just beofre /forums/images/graemlins/grin.gif
  13. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Im having the exact same problem with my setup. I am getting a very loud noise that sounds like the edge of a gear hitting something. It only happens during deceleration and when the engine load levels out at speed. I am getting the noise in my NP203 range box for the WMS Dual case setup I have. I just spent some cash on the rear shaft - upgraded it to 1350 front and rear and now I might have to install a CV rear shaft. I will try to point the 14 bolt down a little to get the correct angles.
    Jesse, is it true that proper driveline angles should be within 1 degree with a Non-CV shaft?
    The rear shaft on mine is 36" long and has 1350 attached to the T-Case and 1350 slip yoke on the 14 bolt. The rear output is nearly level on the NP205 and the 14 bolt is pointed upward toward the NP205 yoke (inline with the d-shaft). Could this be my shaft chatter problem?
    I believe the part about the shaft making the gears inside your cases chatter - expecially with a Doubler.
  14. agk5
    agk5 Registered Member
    Mar 23, 2003
    14
    College Station Texas
    i have an 82 with 4 inch lift, and am running into the same problem. im about to replace the rear shaft with a cv shaft. i also poked around and saw that my front shaft was rubbing the crossmember. check your front shaft for rub marks right around the cv where it hits on the crossmember. i think minor trimming can fix it if we share the same problem
  15. Blazinaire
    Mar 17, 2002
    1,262
    Santa Maria, CA
    [/ QUOTE ] I had that problem, installed a superlift front driveshaft spacer and that solved the problem. In the rear I also had the chattering problem until I lowered my t-case (my pinion is pointed toward the t-case with a non-c/v shaft) it still happens from time to time but when it does it is very faint. I am looking into getting a c/v shaft anyway so I can put my t-case back up where it belongs (what's the point of lifting if you just have to lower stuff to make it work? /forums/images/graemlins/confused.gif)
