t-case mounted p-brake?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chris Demartini, Aug 6, 2000.
  1. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I've seen this on Samuris, theres a local company http://www.spidertrax.com that makes them for use with they're disk conversion. I want to do something similar since I will be cahnging to rear disks very soon, and I would like to use front calipers and get my p-brake cables out of the way. TSM makes a pinion-mounted p-brake for ford 9" rears, so would it be possible to bolt the rotor to the t-case side of the driveshaft and make a caliper mount? Anyone else considering this?</font color=blue>
    http://www.chrisd71k5.coloradok5.com <font color=blue>Updated!</font color=blue>
  2. CK5
    May 19, 1999
    21,627
    704
    CO
    I have seen this setup on a Toyota before and really like it, I will check around a little, if anyone makes it I will test it.
    Steve Fox
    90 3/4 ton K5
  3. River
    River 1/2 ton status
    May 8, 2000
    121
    Amstelveen, Netherlands
    Mabe ìt`s possible to do the same thing like a RV (motorhome) on the big ones thier is a drum brake in the drive line just behind the transmission you could use it as a park brake.
    Greetings from Amsterdam,
    River `89 K5, 350, TH700R4, NP241, "33, 2.73, 10 bolt F, 12 Bolt R
  4. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    The TSM company that makes disk brake converisons kits USED to make this to fit an NP205. I looked about a year ago and it was not listed anymore. Maybe you'd give them a call.
    Squash
    http://www.trailrunners4x4.org/users/realsquash
