t-case popping out of gear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Feb 7, 2002.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    I have a np 208 that in 4hi and 4lo will pop out of gear under tork. What could cause this and is there any fix? A friend told me to just use a bungie cord to hold it in place.
  2. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i had the same problem....but with my body lift the hole in the floor wasnt big enough, and under tork the case would rotate, hit the floor panel and shift it outta loc. very odd, but something to keep in mind
    beligerence doesn't justify intelligence.
    <font color=blue>wheelers hate posers.</font color=blue>
    <font color=red>79k15/400/700r4/205/38.5</font color=red>
  3. blazing86
    Dec 24, 2000
    290
  4. blazing86
    Dec 24, 2000
    290
    anyone else?
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Check this thread for more ideas: <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=325774&amp;page=0&amp;view=collapsed&amp;sb=5&amp;o=7&amp;part=>http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=325774&amp;page=0&amp;view=collapsed&amp;sb=5&amp;o=7&amp;part=</a>
  6. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    had kind of same problem, only in 4hi prior owner had put in a POS t-case drop found that linkage was not adjust correctly. Don't know if you have a drop but check. does your gear indicators line up on your t-case shifter?
  7. blazing86
    Dec 24, 2000
    290
    it 2hi it does not line up, but i never have a problem with it popping out of 2 hi
    in 4hi and 4lo itpops out but the indicator is on them
  8. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    my indicator would not line up on 4hi or4lo case would only pop out of hi range. shifter felt like t-case was not fully lock in. maybe the sucker just worn out?
