T-Case Problems Help!!!
Discussion in 'The Garage' started by Camorokkrwlr, Jul 8, 2005.
  1. Camorokkrwlr
    Camorokkrwlr Registered Member
    Feb 11, 2005
    23
    reno nv
    I have a 79k5 with a th400/208 and my t-case just randomly pops out of gear and then if you run the t-case shifter back and forth through the gears it will finally grab and thenit like normal till it does it again any ideas???
    stan
  2. royjones
    royjones Trucker upper Premium Member
    Jul 6, 2005
    629
    6
    somewhere close to ya
    what about the linkage where the tr case shifter is hooked up is it lose
  3. Camorokkrwlr
    Feb 11, 2005
    23
    reno nv
    tcase problems help!!!
    nope its all tight the linkage is fine but its actin like it pops out of gear when i let off the throttle i dunno it rather frustrating :mad:
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Without looking at it , I would still think the case is going to need rebuilt or replaced . Sooner or later it won't grab anything but 4 low .
  5. Camorokkrwlr
    Feb 11, 2005
    23
    reno nv
    will a 203 bolt up to my th400 :confused:
  6. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    stay with the 208, I hate my 203 but yes it will bolt up to a 400 with its adapter
  7. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    pardon the hi-jack
    but my 208 does something similar..it will stay in 4hi no problem in the snow and mud..but when in a rocky/bumppy area..it would always pop into neutral...the ex always had to hold the shift lever or, i had to put in 4lo, as it never came out of 4lo..
  8. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    Check all the bolts..
    You should try checking all the bolts that hold the T-case to the tranny,Crossmember,and adapter...also the crossmember itself to the frame--if the case can move around due to loose bolts or mounts,it will make it pop out of gear...
    But the 208 case seems to have its share of shifter fork woes,and some guys have told me the rear output bearing's snap ring can break,and cause it to either pop out of gear,or not allow you to get all the "ranges"..I think the 208 in my 82 K20 has that problem--it will not come out of 4wd when I shift it to "2HI"...it just feels "limp" when I shift it into "2HI",like nothing inside the case is moving,(or the "fork" isn't disengaging the 4wd gears) ..so I have to drive it with the hubs unlocked,and let the driveshaft and axle shafts spin all day.Adjusting the linkage did nothing.. :mad:
    ..I bought a spare case,but the guys who told me about that snap ring say its not a hard job to fix--but I dont like fooling with T-cases--too many needle bearings in them,and I have BAD luck with those things!--I'd rather throw the "spare" case in and fix the other one after its out of the truck...I tried "fixing" one IN the truck once,and all the needles spilled into the case when I pulled the tailshaft off...had to pull it out,and I ended up getting another case.. :crazy:
  9. Camorokkrwlr
    Feb 11, 2005
    23
    reno nv
    i need to get it fixed soon cuz its my dd i have a np203 mated to a th350 and was wondering if the 203 will bolt up to my th00 with the parts i have :confused: i just dumped almost 3k into tires and wheels so i dont have much money to play with
  10. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    get back in gear
    Before you condemn it make sure the motor mounts and transfer mount are good. Mine was doing the same thing so I was going to swap it when I had to pull the engine. Pulled the engine to find the mounts were both broken along with the transfer allowing the transfer to move while the linkage stayed stationary allowing it to pop out of gear when I would let of on the gas real hard.
  11. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    TH350 T-case wont fit a TH400
    The TH350 has 27 splines on the output shaft--a TH400 has a larger shaft with 32 splines...its possible to swap a TH400 input into theTH350 style T-case,but it means FINDING one off a TH400,(rare)and gutting it!--you might as well just put the whole case in and be done with it..
    ANY T-case can be installed--IF you have the appropriate adapter,and the input on the T-case matches the tranny output shaft..and the driveshafts will likely need modifications(might need to be longer/shorter!..
    Its always easier to fix whats already there...its nice to "beef up" things,but sometimes its not really nessasary.and can waste a lot of money...a TH350 and a NP208 are not "weak" by any means..not bulletproof either-- :crazy:
  12. Camorokkrwlr
    Feb 11, 2005
    23
    reno nv
    grrr
    all motor and tranny mounts are good. i think i am gonna find a 205 for it cuz rather than spend the money and rebuild my 208 or convert my 203 it would be about the same price range to find a 205. i dunno im so cunfuzled :confused: about it and dont know what to do... i need to get it fixed quick tho....anyone wanna buy a blazer lol jk..might just scrap my whole running gear and swap in a duramax :D
