t-case problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Oct 21, 2001.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    First of all i have a reman. np 208. It pops out of 4hi every time i put it in and pops out of 4lo every once and awhile,. Any ideas what is causign and how to fix?
    Next, i have noticed that the floor board above the slip yoke is covered in atf. But there is no atf on the t-case. I think that it is leaking when the drive shaft is moving but the seal doesnt look bad. Any ideas?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have the same problem, and I was told that the rear seal is bad.
    My Chevy isn't broken, its just out of gas.
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    They all leak like that...
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  4. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Do you have a body lift?
    Still Poundin' "pavment" after all these years!!! [​IMG]
  5. TXBIGFISH
    TXBIGFISH 1/2 ton status
    Oct 2, 2001
    297
    Sachse TX
    Sounds like a common problem. Mine does that too. I figure it needs a rebuild. I have 2 hi and 4 low but 4 hi is sketchy at best. I feel better now that I know others are having the same problems.
    &lt;*)))&gt;&lt;
    81" GMC Jimmy.............stock for now!
    IT'S A DOG EAT DOG WORLD OUT THERE, AND I'M WEARING "MILK BONE" UNDERWEAR!!!!!!!!
  6. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Anything lifted, with even the slightest that causes any kind of vibration is going to cause that seal to wear out and distort quicker. I got ATF all over the back and i think its great for a rust preventer. Hey i have to justify it somehow. - Doug
    Doug Krebs
  7. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    mine doesnt do any of that ...... oh yea i have to keep replacing the housing cuz i keep breakin em , i need driving tips ..
    WHATS WRONG WITH A 305 ?
    81 K10 GOODYEAR 35" MTRS
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
  8. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Mine pops out of 4 high also....Dan
    If it ain't broke.......Don't fix it....
    <a target="_blank" href=http://coloradok5.com/gallery/Gokartergo>KLICK</a>
  9. Tatman
    Tatman Registered Member
    Oct 2, 2001
    80
    Indiana
    I have an np203 and it use to pop out of 4HI all the time too. All it needed was an adjustment. Works fine now. As for the ATF... mine does too. Must be a K5 thing.[​IMG]
    Brian
    <a target="_blank" href=http://www.saddletramps.com/BlazerK5.htm>www.saddletramps.com/BlazerK5.htm</a>
  10. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    Mine pops out of 4low and the rear seal wears out fast. Tired of replacing them so I like the idea of a rust preventer. I'll use that. Look at your linkage for the t-case, might need adjusting.
    Brian
    83 K-5 4" on 33's
  11. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    Check the shift linkage, sounds like it needs adjustment. The oil around the slip yolk is common to a certain extent.
    '79 K5, '79 Suburban, '76 Br**co, 77 K20
    '99 BB 4x4 Suburban to tow more junk home
  12. eastk5
    eastk5 Registered Member
    Jul 24, 2001
    50
    Norfolk Virginia
    I have the rust prevent also. but i haven't experienced the t-case popping out of hi or low
