T-case Q?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazen91, Nov 3, 2000.
  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Will a 208 bolt up in my 91 that currentlly has a 241? And which one is better? My 241 is spitten' fluid and no one can tell me why, and I know where a used 208 is I can get cheap. Thanks for any input.
    blazen91
  2. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Some one has got to know something!PLEASE!!!
    blazen91
  3. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    I am asumming you have a 700r4, in that case i believe it should, but one thing you might want to look at is how long the 241 is. your driveshafts may have to be lenghten or shortened depending
    Doug Krebs
  4. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Strength is about the same on the 208 and 241, they r both aluminum. As far as gearing goes the 241 has a lower lo gear I think its 2.72:1 and lo in a 208 is 2.61:1. You have the 4L60 tranny right, it should have the same bolt up pattern that a 700r4 has(99% sure) which was mated to a 208 or (optional) 241 in some of the later 80's.
    Hope this helps. You shouldn't have a problem bolting up a 208 to your tranny (98.9% sure), somebody correct me if I'm wrong.
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red>, it's a population control thing.</font color=blue>
  5. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Thanks guys. I may not have to change it now though. I was talking to a buddy about the oil the T-case was spittin' and he said his did the same thing, so he ran the breather up under the hood almost to the hood. Where does your t-case breather run to?
    blazen91
