T-CASE QUESTION
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dheavychevy38, May 12, 2003.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    I SWAPPED A 1986 208/700R4 SETUP OUT TO A 91 SETUP WITH A 241 THE PROBLEM IS THE SPEDO CONNECTION IS THE END OF THE CASE SWAPPABLE ???? ANY HELP WOULD BE GREAT /forums/images/graemlins/truck.gif /forums/images/graemlins/k5.gif
  2. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    MNorby went from a 700/208 to a 400/241 and he couldnt switch the speedometer due to the new one was electronic and the old one was gear driven, i would guess your gonna have the same problem.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    You can convert your 91 NP241 to a mechanical speedo by using the parts from a 89 NP241, I am pretty sure you cannot use the 208 parts though.
  4. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    THANKS GUYS DO YOU KNOW OF ANY T-CASE THAT WILL BOLT UP TO THIS TRANS CAUSE I HAVE A ONE 205 TWO 208'S AND TWO 241'S AND A 203
  5. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I don't but I'm guessing IF YOU TURN OFF CAPS LOCK YOU MAY GET MORE REPLIES. /forums/images/graemlins/thumb.gif
  6. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    sorry didn't know it made a differance in the respond
  7. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    It depends on what trans was infront of the cases originally. If they are 27 spline t-cases, then any of them can be bolted up.
