t-case rear output bearings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by myklnglo87K5, Jun 24, 2003.
  1. myklnglo87K5
    myklnglo87K5 Registered Member
    Aug 22, 2001
    10
    Kent, WA
    I have a 208 t-case on my 87 Blazer. The rear output shaft has a bit of play. Is some play normal or is that a sign of worn bearings? I have a vibration problem and replaced/balanced near everything else that might be a problem. Before I dig into the output shaft, I thought I'd ask. I think I need to replace my tranny mount too, or at least the t-case mounting, just in case that could be a factor also.
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    you might need to replace the metal bushing that the slip yoke rides in. it's just inside of the output shaft behind the slip yoke seal. it's like $7 at the dealer.
  3. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    how does one replace this bushing? /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Just take out the tail housing, remove the seal either with a screw driver or a seal remover, and then from the inside using a pipe or socket or the proper bushing remover to tap the bushing out.
    Installation is reverse.
    /forums/images/graemlins/thumb.gif
  5. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    it's a good idea to put the bushing in the freezer the night before so that the cold will shrink it just a little bit to make it a little easier to put the bushing in the housing.
  6. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    well at autoloan you can get a seal\bushing kit for 8$, and knowing how to do this makes me feel better /forums/images/graemlins/thumb.gif. well now that i know what and how to replace that bushing, i can sleep well tonight /forums/images/graemlins/thumb.gif.
