T-case Shift Grinding
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84Blazr, Jan 11, 2001.
  1. 84Blazr
    84Blazr Registered Member
    Nov 29, 2000
    50
    Stillwater, New Jersey
    I got an obnoxius grinding when i try to shift out of low range and i can't get it out until I shut the truck off, then if shifts right out. Why is this? I got a 208 case, 700r4, just body lift w/ 35's, and I do go the tranny in neutral when I'm shifting in/out of low....Is there some kind of stress binding it up? has this ever happpened to anyone else? Thanks.
    Know any GOOD Wheelin' in Northwest Jersey, let me know?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Are you shifting the transmission to neutral first? That usually makes it a lot easier to shift between ranges.
  3. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    Try backing up while turning the wheel back and forth to relieve binding on the driveline, don't know much of 208's-check linkage?
    "I'm not stuck...I'm just exploring the depth and texture of this mudhole for a while"
